Replacing head gaskets on a 5.2 engine
Old Mar 12, 2011 | 04:34 PM
  #21
Evon Trizmo's Avatar
Evon Trizmo
Very true on the CAT probably being destroyed with how rich it has been running, it's rattling pretty badly too so deffinatly time for a new one. I just want this whole nightmare with no power and the exhaust to be over with already. I wouldn't mind installing a new CAT back system to get a nice sound and lots of flow from it.
Old Mar 12, 2011 | 06:19 PM
  #22
Mean Green's Avatar
Mean Green
In the future if you are thinking you have a vacuum leak get a can of carb cleaner, run the engine and spray the vacuum lines and intake manifold gaskets. If the engine revs up you've found your leak.
Old Mar 12, 2011 | 06:51 PM
  #23
Evon Trizmo
The carb cleaner trick was always in the back of my mind but I never got around to trying it. I figured if there was a leak it wouldn't idle as low as it normally does. But that's deffinatly a good way of checking for leaks, the vacuum basically pulls in the cleaner and burns it which makes it rev a little more.
I am interested in your E-fan conversion and looking into doing the same, I figure every little bit of load off the engine will help MPGs in the long run.
Old Mar 13, 2011 | 03:28 PM
  #24
hydrashocker's Avatar
hydrashocker
Originally Posted by Evon Trizmo
Here's just a few questions, anyone know if these engines actually have exhaust manifold gaskets? First engine I saw without them, unless somebody even more lazy than me was there first and just didn't put any back on.
Also would I need to be all professional and actually go out and buy a torque wrench for the head bolts, or would I get away with doing what every other poor kid does which is find a socket that fits on the handle of his ratchet and then put together all the extensions in his toolbox on that socket to make a long redneck breaker bar and pull into it don't turn no more? And no I didn't get new head bolts, I know I should but I'm poor remember, besides if I borrow one more extension from my neighbor I just might get them bolts to strech again haha, you never know.
And my last question, I promise, anyone know of a good way to get all that old sticky gasket and dirt and whatever 13 years of buildup off the gakset surfaces?
I have a round wire brush thinger that you put on the end of a drill and it spins, but would it be ok to get all that junk in the oil and cooling system, then do an old change and coolant flush after 100 miles? Or is there a better way I have not yet thought of?
Things are moving along smoothly, I'm be sure to post pictures of the job soon once I get them uploaded, everyone likes pictures.
1. The motor did not come with exhaust gaskets from the factory that I remember. You would be smart to install a set.
2. If you are going to use the old head bolts you should torque them a few lbs over the specifications. I wouldn't personally not do a head gasket without a torque wrench because you are not only stretching the bolts but collapsing the gasket as well. Ensure you tighten them in sequence following the manual. You can get a cheap one at Harbor Freight for like $15 or barrow one.
3. I use gasket scrapers like these: http://www.alltradetools.com/catalog...t-scraper.html or even a dry wall spreader at your local store for like $1. You have to make sure that you DO NOT maul or pit the surfaces of the block or head. You scrape off the large pieces and ensure the mounting surfaces are clean using alcohol or brake cleaner. You can cover the water and oil jackets with old rags pushed in them. Don't forget the cylinders! Put old rags down them as well and before you remove the rags use a vacuum to suck the crap out then suck the cylinders out for anything else and remember that crap can fall between the cylinder wall and the piston to vacuum the real good.
Old Mar 13, 2011 | 04:43 PM
  #25
Evon Trizmo
Exactly the kind of answers I was looking for Hydra. I never attempted anything like this before so I just worked with what I had, but deffinatly good advice to hold onto for the future.
Old Mar 13, 2011 | 08:38 PM
  #26
hydrashocker
If you need specified help, I've been there before just PM me.
Old Mar 15, 2011 | 12:37 AM
  #27
Evon Trizmo
Well guys here's the last update. The exhaust shop says blocked exhaust, they cut the pipe before the CAT and it got all it's power back, runs like new. In case any of you are wondering what it sounds like now, here's a video we made of it http://www.youtube.com/watch?v=mu8UnMtNIeI haha it's great. Tomorrow I'm getting a new cat., O2 sensors and a muffler so that will make it run perfect.
The redneck head gasket replacement was a success! no problems for over 500 miles so far. The shop wants $120 for a coolant flush, I said in your dreams, so I'll look into how to do that sometime, it's running much cooler than it ever was now at about 195 degrees, which is the same temp as the new thermostat I installed too so it's working. Would have gone with a 180 degree but everything I read said a warmer running engine will get better MPGs so that sold me on a 195 right there.
All together I spend under $80 on everything I needed to install the new head gaskets. Mostly going as cheap as I could. I saved at least $600 doing it myself though. Overall it wasn't hard as much as it was time consuming, so if anyone is thinking about doing it too, I say go for it, just remember where everything goes and pray you don't have the dreaded "extra parts" when you get done. If you have an extra header or pushrod laying around when you get done I think you did it wrong.
Well that's about it for this thread, just logged my work and shared my experience for anyone out there who is interested. Best of luck to anyone who wants to give it a try.
Old Mar 15, 2011 | 01:15 AM
  #28
WhiteWidow00's Avatar
WhiteWidow00
Well there goes the neighborhood!!
Old Mar 15, 2011 | 11:00 PM
  #29
hydrashocker
Sorry, but........when TF did we get to the motor being completed done and ready to go?
Anyway, sounds to me the motor is drowned and in need for a tune up and the trans a sift kit.
Old Mar 15, 2011 | 11:13 PM
  #30
Evon Trizmo
Post #11 was the first time having it all together completely and starting/running it with timing issues. Then post #19 I took the water pump and timing cover off to replace the chain and correct the timing, after that it ran perfectly except it still had a badly restricted exhaust. So yesterday I took it into a muffler shop, they cut the pipe before the cat. to open up the exhaust and it gained all it's top end power back and all was good, that's when I made the video that day too. Then today I took it back to the muffler shop and they installed a new exhaust system. If anyone wants pictures of cleaning the intake and heads, it all put back together and being complete just say so.
The motor shifts very diffrently with the open exhaust for some reason, long smooth shifts. I wouldn't mind getting a tune up and a nice transgo shift kit and even a superchips programmer, but I have absolutly no money for anything. I just do what I need to do to make it move from A to B.
