Stumbled upon something that may help you infinity guys out.
Old Mar 8, 2011 | 12:11 AM
Biff85ta's Avatar
Biff85ta
Default Stumbled upon something that may help you infinity guys out.
I was looking for solutions on my 01 Caddy speaker which are one ohm. I came up with the idea of using resistors to make up for the difference so I did some research and sure enough that will work. You guys would need the correct wattage 4 ohm resistor to make a 4 ohm speaker 2 ohm if you wired it in parallel and make the factory amp happy.
Old Mar 8, 2011 | 08:45 AM
WhiteWidow00's Avatar
WhiteWidow00
True that! As long as it would work (don't see why not) sounds like a great find Biff!
Old Mar 8, 2011 | 11:19 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
mathematically, and theoretically speaking, it would work, however i havnt tried it
Old Mar 8, 2011 | 08:13 PM
Duranged408's Avatar
Duranged408
Screw the resistor, Just add another 4ohm speaker
Old Mar 8, 2011 | 09:01 PM
Biff85ta's Avatar
Biff85ta
That works too if you can find room for it.
Old Mar 9, 2011 | 09:12 PM
DurangoRT/RN's Avatar
DurangoRT/RN
I need all new speakers.
I am going to need to read up again about them and what I should get.
I remember it's not an easy fix and I don't want to buy the wrong thing and have them rig it wrong. But I would LOVE to hear a great system in my truck... again
Old Mar 11, 2011 | 12:10 PM
hydrashocker's Avatar
hydrashocker
You can find it in here: https://dodgeforum.com/forum/1st-gen...wers-faqs.html
Old Mar 11, 2011 | 04:07 PM
HellzMindPlaya's Avatar
HellzMindPlaya
So i did some reading on this very subject yesterday and that leads me to this question... if you wire a resister in parallel with a speaker on the same channel on an amp wouldn't the resister get 1/2 of the power? Sounds like a waste to me.
Edit: Which means that you shouldn't get any more sound out of the 4 ohm speaker... and the amp should be able to drive the 4 ohm speaker just fine by itself... but I am just guessing like everyone else, never tried it, will have to some day though, my front drivers side speaker is not working (mid or tweet.)
Old Mar 11, 2011 | 11:49 PM
Biff85ta's Avatar
Biff85ta
http://www.crutchfield.com/s_1081209...s%7cFFFree_Air
This sub is what got me thinking about it. I could not imagine what other way to have a selectable Ohm load via a switch except a resistor.
