Help! P1391 crank/cam sensor code
Old Mar 19, 2011 | 03:32 PM
ndibber@topeka.org's Avatar
ndibber@topeka.org
fixed it! it was the drive plate/flex plate. I filed down the openings where crankshaft sensor reads and it is fine now runs like a champ. The transmission shop that rebuilt the transmission had messed them up when they were installing the transmission the used the holes to turn the engine over by them.
Old Mar 19, 2011 | 03:45 PM
Evon Trizmo's Avatar
Evon Trizmo
Awesome to hear you got it fixed, sounds like you got into a huge project swaping out drivetrains. It sucks when something small and stupid like that keeps everything from going smoothly.
Old Mar 19, 2011 | 06:58 PM
hydrashocker's Avatar
hydrashocker
Just watchin...........
Just to let everyone know:
It's also called a "Pickup Sensor". It is located under the distributor.
Camshaft sensor
Cam sensor
Also, you have a Crankshaft sensor on the rear of the motor on the passenger side.
is there another name for the cam sensor because all the parts stores i call say the 5.2 does not require or does not have a cam sensor
Good to see you figured it out! Great mechanicing skills I might add!
Old Apr 6, 2014 | 04:32 PM
harveyandy99's Avatar
harveyandy99
Default 2002 durango
i went and swap 2002 to 2003 and now it wont start due to crank and cam sensor i erplace them it still wont start and same code HELP!??
