Fix your heated seats for free
Old Oct 13, 2011 | 08:17 PM
  #21
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup open element is what this thread is addressing (video seems broken), in my case the element was broken (open circuit) in the bottom pad of the seat.
Old Oct 26, 2011 | 06:20 PM
  #22
ballardde's Avatar
ballardde
I followed your instructions, found the burn mark in the heating pad, but the wire itself (at the burned area) is not burned. The wire still has the insulation on it and is in one piece. Is this still the suspect area? Thanks.
Old Oct 26, 2011 | 08:57 PM
  #23
shrpshtr325
THE ULTI-MOD
yes you will have to cut the insulation open to see if the wire is intact, but since you found a burn mark chances are that it isnt, even if the insulation is
Old Oct 26, 2011 | 11:38 PM
  #24
hydrashocker's Avatar
hydrashocker
Say what?
Old Oct 27, 2011 | 09:53 AM
  #25
shrpshtr325
THE ULTI-MOD
ok jack go away, what i am saying is the wire most likely broke inside the insulation and the insulation is still intact
Old Oct 27, 2011 | 12:21 PM
  #26
ballardde's Avatar
ballardde
Okey doeky! Thanks! I will investigate that area. Also, this is a 2003 Durango SLT Plus, under this seat there is a white connector. The black wire has been cut from this connector and bypassed/connected directly to the black wire coming from the floorboard. In other words, the white connector has been bypassed. This was this way when I bought it. Any idea what that would have been done? Also, do the heater elements plug into the seat motors? I can't find a direct connection from the floor to the heating elements. Sure appreciate your help.
Old Oct 28, 2011 | 04:35 PM
  #27
ballardde's Avatar
ballardde
Just got done putting the seat back in and it WORKS! I now have a working rump roaster just in time for the cold weather. Thanks a million for posting this information, can't imagine how much money you saved me.
Old Oct 28, 2011 | 04:57 PM
  #28
shrpshtr325
THE ULTI-MOD
iirc there are two plugs under there, one for the motors and controls and one for the heaters
yup two plugs, a white one and a green one
the colors could be different on the 2003 but it should be the same connections going to the same places.
glad i could help and glad you got it fixed.
Old Nov 15, 2011 | 09:55 AM
  #29
ballardde's Avatar
ballardde
Just a follow up . . . heated seat continues to work, thanks again for the initial writeup and the follow up to my questions.
Old Nov 15, 2011 | 03:02 PM
  #30
shrpshtr325
THE ULTI-MOD
good the hear
