Looking for help with stall problem
Old Mar 19, 2011 | 03:55 PM
Ondelas's Avatar
Ondelas
Default Looking for help with stall problem
2001 durango r/t
if i drive through a puddle of water at a decent speed the truck stalls out also if i get a drive through car wash with under spray it also stalls but when its raining out nothing, when this happens i get the error code 0123 for TPS but how would a puddle or under spray a bit of water stall me out like that? any input would be great thanks
Old Mar 19, 2011 | 04:27 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds to me like you have water getting into a sensor on the underside of the vehicle and shorting it out, check the tps connector (since that code comes up) and follow the wires down, maybe there is a bare spot on them at some point in the wire loom which gets wet and causes the problem
Old Mar 19, 2011 | 05:10 PM
WhiteWidow00's Avatar
WhiteWidow00
Yeah, I believe there is a short in the wiring related to the TPS that is shorting to ground. Make sure the TPS on the side of the throttle body is secured on tightly because if it's not secure enough or something when it rocks it will cause it to stall.
Old Mar 19, 2011 | 06:51 PM
Old_School's Avatar
Old_School
i agree water is getting somewhere it should not....
Btw Mr.widow i answered your PM sorry it took so long i didnt know it was there till yesterday
Old Mar 19, 2011 | 07:01 PM
hydrashocker's Avatar
hydrashocker
You might wanna replace the TPS.
Old Mar 19, 2011 | 09:04 PM
Evon Trizmo's Avatar
Evon Trizmo
I'd go ahead and replace the TPS. If it sputters/misfires and then dies when it gets wet, you most likely have water getting in the distributor which is also common.
Old Mar 20, 2011 | 02:37 PM
Ondelas's Avatar
Ondelas
searched every wire to and from the TPS all seems mint, replaced the TPS went to the carwash...soon as the underspray started stalled takes 5 min to start again like its resetting or something when it starts it sputters for 2 secs then fine so ill guess i check distributer evon thanks for the tip ;( the engine doesnt even seems wet when i poped the hood this sux
Old Mar 20, 2011 | 03:41 PM
Evon Trizmo
Next time it gets wet and won't start, get a hair dryer on the distributor cap, ignition coil, and spark plug wires. Do each one seperately and see what you issue is. It could just be bad spark plug wires shorting out.
Old Mar 20, 2011 | 04:25 PM
hydrashocker
Could be a Cam sensor or alternator issue.
