Dodge Durango Shelby SP360 - Need Help!!!
Old Jul 25, 2011 | 01:01 PM
  #21
ildar's Avatar
ildar
Hi!
And again
Has put other compressor, has left the conducting only.
As has established candles, wires, ignitor.
The result isn't present
On netral 8-10 psi on the move 5-6 psiWhether can the belt slides?
Or leaks in vacuum tubes? Visually all whole.
knok sensor and optimaser changed
Old Jul 25, 2011 | 01:26 PM
  #22
ildar's Avatar
ildar
Who will tell as to calibrate TPS?
Old Jul 25, 2011 | 04:15 PM
  #23
hydrashocker's Avatar
hydrashocker
Old Jul 26, 2011 | 03:00 AM
  #24
ildar's Avatar
ildar
Thank you!
Simply connected the computer through OBD2 and TSP showed 6 % when not step pedal and 71 % full to an acceleration
Old Jul 26, 2011 | 11:09 AM
  #25
hydrashocker
You should be closer to 13% at idle and 100% at full wide open throttle.
Get a oversized drill and remove the brass inserts on the TPS. Then get 2 washers and set the TPS to 13% (0.7 - 0.73 volts). Then tighten it back down and take measurements again. Just follow the instructions on page 20-21, instructions are 1 - 10.
This should take care of the stumble you have on acceleration.
Old Aug 10, 2011 | 11:19 PM
  #26
ildar's Avatar
ildar
Thanks big.
Has made as you have told, the car has gone better.
Has measured pressure of fuel - usually 3.5 kg/cm2 but by sharp pressing of an acceleration falls to 2.8 kg/cm2.
How you think it can be - the main problem?
The fuel pump looked - it without a fuel adjuster gives - 6-7 kg/cm2.
There is a sense to order the new pump?
Old Jun 16, 2012 | 10:18 PM
  #27
Paveitall's Avatar
Paveitall
Hello, I'm new to this site but I'm wondering if you have any info on #192?
Old Jun 17, 2012 | 01:43 AM
  #28
IndyDurango's Avatar
IndyDurango
She's a 4x4 from Pennsylvania. PM Sent.
IndyDurango
Old Jun 18, 2012 | 07:21 AM
  #29
ildar's Avatar
ildar
new configuration
Mopar Performance P5007852
fuel Bosch 0280150845
65lbs
ecm - autronic SM4
electronics- Blitz Racing monitor DC
in plans a roller - 2.5 inches
to change an exhaust
Old Nov 7, 2012 | 05:38 AM
  #30
ildar's Avatar
ildar
roller - 2.35 inches (10-13 psi)
water intercooler
http://carbook.kz/album/266/photo/6438
http://carbook.kz/album/266/photo/6437
http://carbook.kz/album/266/photo/6439
