eze
Old Mar 22, 2011 | 04:23 PM
eze's Avatar
eze
Default eze
I am brand new to forum I have a 2000 durango with po171 MAF issue. What I cannot do is locate this part. Does any one out have the exact location of this part or a diagram that shows where this part is? HELP need to clean or replace ASAP THANKS
Old Mar 22, 2011 | 04:25 PM
eze's Avatar
eze
I need the exact location of the MAF sensor on my 2000 Durango. HELP
Old Mar 22, 2011 | 06:30 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Moved to the first generation Durango section,
FF
Old Mar 22, 2011 | 06:32 PM
WhiteWidow00's Avatar
WhiteWidow00
Welcome to DodgeForum! First off, the Durango doesn't have a MAF sensor, it has a MAP sensor and which engine do you have? The 4.7 and 5.9 was offered on that year and they are in different parts of the engine.
On the 5.9 engine, the MAP sensor is on the front of the throttle body and has a vacuum line coming from it. It's a small black box and hard to miss.
IIRC, from others saying I believe the MAP sensor on the 4.7 engine is on the intake manifold and behind the A/C compressor.
EDIT: Check your other post as I was a bit more specific.
https://dodgeforum.com/forum/1st-gen...l-durango.html
