2001 4.7 engine swap questions
Yes it can be done, however both engines use two diffrent transmissions, so those will have to swap out too. The transfer case bolts up to either transmission so you can keep that. You will need to move a ton of wiring because the PCM will also need to be replaced. Your best bet is to locate a 5.9 engine and PCM from a 2001+ model and use that.
it can be done, but as stated you will need to swap the following (i think he missed a couple things)
1.engin
2.transmission
3.wire harness
4. i believe the motor mounts are different
5.computer is different
6. im pretty sure there is something else, but i cant think of it off the top of my head, but its going to be a HUGE project, just so you know what you are getting into before you start
1.engin
2.transmission
3.wire harness
