P1732 and P1784 trans code HELP PLEASE
Old Mar 26, 2011 | 09:47 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by coreybv
The ability to put air in your own tires is not on the list of requirements to get hired at a parts store.
lmfao!
Old Mar 30, 2011 | 04:54 PM
rawpower1417's Avatar
rawpower1417
I was told by a dodge tech that my tcm has went into retarded mode. His words not mine. He said to replace all the fluid then take it to the dealer have them clear the vlp's and do a quick learn. Again his words. I was told that on another forum and the tech is not in my state. So does it sound possible
Old Mar 31, 2011 | 01:34 PM
hydrashocker
I don't think you have an option.
Your going to have to purge all the trans fluid out of your trans and replace both filters. Then drive it for like 100 miles and do it again. You need to use ATF+4!
As for the re-learn, you might be able to get around that. The codes will clear on their own after some time, but I would just reset the PCM and be done with it.
Here is the PCM reset instructions: https://dodgeforum.com/forum/1st-gen...ine-light.html
And here is the DIY section: https://dodgeforum.com/forum/1st-gen...wers-faqs.html
Specifically under the ATF fluid section, how to purge the trans: https://dodgeforum.com/forum/1st-gen...nsmission.html
Old Feb 11, 2014 | 01:44 PM
asphaltwarrior1's Avatar
asphaltwarrior1
Originally Posted by hydrashocker
Hydra forgive me for raising the dead here but my Rango threw a P0700 code and I went to my buddies shop and we scanned the Rango and the TCM gave up a P1784 code. I found out that this code is for a " Low and Reverse Clutch Pressure Switch Circuit Malfunction. Could this code get added to that awesome list of codes you posted up? Thanks for that list by the way, I need to print that sucker out .. AW1
