Trans fluid??
Old Apr 1, 2011 | 08:40 AM
  #21
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yea t-case is just like the trans, if you put anything but ATF+4 into it you are asking for problems
Old Apr 1, 2011 | 11:27 AM
  #22
MAGIC84's Avatar
MAGIC84
ATF+4 sounds familiar. I had Oil Change, differential and Transfer case servicing although I can't find the invoice now, ATF+4 sounds familiar. I am not trying to backtrack on my original answer but I remember getting ATF+4 when I was going to do it myself (Before I remembered my gravity lessons and realized that it is easier to have the pros insert with filling gun)...Yes I ran a couple of weeks without fluid in the X-Fer case. I drained but wasn't able to fill. NOTE: I remembered it was without fluid and it was well before Winter and 4X4 was not used. When I hit Valvoline I got the Oil Change and pre winter Differential (Frt/Rear) and Transfer Case servicing all done at the same time.
Old Apr 1, 2011 | 02:17 PM
  #23
WhiteWidow00's Avatar
WhiteWidow00
Glad ATF +4 sounds familiar because differential gear lube is not good to find in a transfer case. LOL
Old Apr 1, 2011 | 11:31 PM
  #24
MAGIC84's Avatar
MAGIC84
You got me there oh wise one. I am going to Start Calling you Hydra Southeast.
Old Apr 2, 2011 | 10:49 AM
  #25
Old_School's Avatar
Old_School
I took a washer fluid bottle out my old Chevy Silverado (there is a motor attached to the bottle) and rigged the motor to plug into the cig lighter that way when i have to fill the T-case or the differentials i just fill the bottle with the right fluid, put the tube in the fill hole and turn it on.....
Old Apr 2, 2011 | 10:55 AM
  #26
MAGIC84's Avatar
MAGIC84
Old, Don't get me wrong I am sure it works but I am not sure which is more redneck about that.........The Chevy Silverado or rigging up the washer pump motor to the cigarette lighter.
Old Apr 2, 2011 | 01:40 PM
  #27
Old_School's Avatar
Old_School
Well, I R one so i guess it fits well...
Old Apr 2, 2011 | 03:12 PM
  #28
hydrashocker's Avatar
hydrashocker
"Hydra Southeast" huh......LOL
Anyway, ya the manual only calls for ATF+4 in all of the Transfer Cases.
This thread does bring up an old coversation however I had with the company that built my T-case in my old Durango. I asked him his opinion on gear oil in the T-case and wether it would be better or worse. Now this shop builds some of the best T-cases OEM or super modified you can buy. So he isn't exactly stupid......LOL
Anyway, we were talking about the NV242HD in particular and he stated that the way it was internally, well it most likely wouldn't matter if I used ATF+4 or 80W-90 but prefered 75W-90 Fully Synthetic. The inner workings of a NV242HD is a basic gear box so it shouldn't matter. I stated that I would rather leave it with ATF+4, but it was kinda fun to bounce the idea off him for his opinion.
Old Apr 2, 2011 | 03:34 PM
  #29
HammerZ71's Avatar
HammerZ71
As for the brand, I've always used Valvoline ATF (currently +4) it's good stuff and I've never had any kind of transmission or transfer case issues in any of the seven full size 4x4 trucks, two Jeep Wranglers and four Grand Cherokees I've owned over the years. Unless I happen to step into a deal like I just did for Royal Purple at 40% off, I pretty much stick to Valvoline Synthetic in the crankcase as well.
And to get off the topic, I also hate that the trannies are sealed in modern vehicles. I changed the oil in my mom's '10 Dodge Journey and went to check all the fluids and was like WTF???
Old Apr 2, 2011 | 11:14 PM
  #30
hydrashocker
I use the same. Valvoline ATF+4 Fully Synthetic because technically it isn't a Fully Synthetic because it's a hydra-cracked base oil, however it's the best out there right now avalible because no one makes a Polly based Fullyt Synthetic base oil for ATF+4.
Now there are ATF Fully synthetics out there like Mobil One and Royal Purple, but they won't, or can't back their product with testing by Chrysler as declaired to meet the copy rights of Chysler to be concitered ATF+4. In other words, if a company claims to be ATF+4 compatable then it must PROVE that they build it to their specifications or better by way of 3rd party testing. Nobody has stepped up to the plate other that Valvoline, which is kinda strange for Mobil One but hey, it costs money.
With that said, Valvoline ATF+4 Fully Synthetic is what I use in my trans and T-case and that's all I use. It only comes in quarts, 5 gal containers, or 55 gallon drums however. They don't make gallon bottles dammit!
