Nv244
Old Mar 31, 2011 | 07:15 PM
SLIMDIK's Avatar
SLIMDIK
Default Nv244
I just bought an 01 durango rt 4x4. on the drive home from buying, the transfer case shattered into cute little pieces all over the highway. it was awesome let me tell you. so now i am looking for a used nv244 to replace it, but all the ones i see on ebay are for 04 05 models. does anyone know if these will work ? by working i mean bolt right up with out any mod what so ever? THANKS
Old Mar 31, 2011 | 07:48 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you posted this in the wrong section, it needs to be in the 1st generation section, as is stated in the STICKY thread entitled Please Read BEFORE Posting in this section!, i will move it for you this time
Old Mar 31, 2011 | 08:01 PM
WhiteWidow00's Avatar
WhiteWidow00
I believe you are looking for the wrong transfer case. The first generation used the NV242 not the 244. Make sure this is what transfer case you have though.
Old Mar 31, 2011 | 10:22 PM
SLIMDIK's Avatar
SLIMDIK
SORRY !!! I thought I did post in 1st generation. Thanks for moving it for me
Old Mar 31, 2011 | 10:28 PM
SLIMDIK's Avatar
SLIMDIK
the t case i pulled has 244 on the badge, and I'm also told that the 242 is the (2wd 4hi 4lo) and that the 244 is the (awd 4hi 4lo) which is what I have
Old Apr 2, 2011 | 01:20 PM
hydrashocker's Avatar
hydrashocker
Incorrect,
In the 1998-1999 there was the NV242HD. Later they pulled it from the market. The NV242HD was a Part Time style T-case with an extra position but was short lived.
In 2000-2003 the R/T model came standered with a 5.9L and NV244.
The NV244 is a AWD transfer case that replaced the older NV242HD.
Anyway, you can check the junk yards or google them, finding one may prove hard to do as they only came in the R/T version.
http://www.automotix.net/usedautopar...ee08&seq_num=2
http://www.autopartsfair.com/dodge-u...ee08&seq_num=2
http://www.automotix.net/usedautopar...ee08&seq_num=3
http://cgi.ebay.com/01-02-03-DURANGO...item1c1087a5a4
I am unsure of the compatability between the 1st and 2nd generations. I would simply call a dealer and ask if they are the same part number or simply look at Auto ZOne or other for the same part number. Here it says it will however:
http://cgi.ebay.com/ebaymotors/01-04...Q5fAccessories
