Check Engine Light Code PO308 and PO445
Old Apr 3, 2011 | 12:43 AM
MRob11's Avatar
MRob11
Default Check Engine Light Code PO308 and PO445
Hi guys I've got a 2002 Durango R/T 5.9l and my check engine light has been on for a while now with error codes PO308 and PO445. I know PO455 has to do with the EVAP system or something and PO308 is cylinder 8 misfire. I've seen other thread about this but all the others say their car makes weird noises. Mine works great and doesnt make any weird noises (exept for my squeeking belt). I've got no mods and i cant see any broken wires or anything. What could cause these problems??? Thanks guys!
Old Apr 3, 2011 | 09:44 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
take a look under the hood at night, see if the plug wires are arcing,
also when was the last time you did a full tune up (plugs, wire, cap, rotor) this could very easily solve the problem if its been a while (btw use ONLY Champion Copper core plugs gapped to .040
Old Apr 11, 2011 | 09:22 PM
MRob11's Avatar
MRob11
Yep that did the trick. Replaced the plugs, wires, ignition rotor, distributor cap (which had some corosion) and the lights gone. thanks!
Old Apr 11, 2011 | 10:00 PM
srch4me's Avatar
srch4me
good call... autozone tried to tell me to replace a seal to fix it... i said heck no...
Old Apr 12, 2011 | 02:52 PM
MRob11's Avatar
MRob11
PO445 is still there though. Anyone know common causes and fixes?
Old Apr 12, 2011 | 04:29 PM
shrpshtr325
THE ULTI-MOD
P0445 Evap Emission Sys Purge Ctrl Valve Circ Shorted
sounds to me like a wire problem on the purge solenoid, or a bad purge solenoid
Old Apr 13, 2011 | 05:12 PM
MRob11's Avatar
MRob11
Thanks but I'm an idiot. I realized i wrote PO445. I meant to say PO455- large leak detected. All these codes are a little confusing lol. Probably a hose going to the solenoid. I'll check.
Old Apr 13, 2011 | 06:44 PM
WhiteWidow00's Avatar
WhiteWidow00
Well if it's P0455 then that's a completely different story and might be an easy fix. Take the gas cap off and put it back on and make sure it clicks 3 or 4 times. Typically the gas cap being on there loosely will throw this exact code so that's where I'd start.
If that doesn't help try replacing the gas cap. $6 is a good place to start before you start throwing money in places it doesn't need it.
Old Apr 13, 2011 | 10:02 PM
MRob11's Avatar
MRob11
Ya thanks but I tried tried that and the code keeps coming up after reseting it. Anyone know were some hoses are that could be cracked and causing this?
Old Apr 13, 2011 | 10:08 PM
WhiteWidow00
With a major leak its likely it's not a cracked hose but a broken hose that's causing a huge leak. Check the main hose that goes from the front of throttle body to the EVAP service port on the driver side firewall. These are pretty flimsy with age and can break pretty easy.
