a simple question
Old Apr 9, 2011 | 01:46 PM
autaurkhos's Avatar
autaurkhos
Default a simple question
can i swap my 98 4x4 trans with a 99 2x trans?i dont have the money to rebuild or buy another but i got a friend with a 992x truck he's parting out.can i use the trans from his truck for my 4x4 durango?if so what mods will i have to do along with the swap?your help would be grateful.
Old Apr 9, 2011 | 02:54 PM
hydrashocker's Avatar
hydrashocker
If the engines are the same, then yes you can.
You will have to remove tail end off the 2wd so it matches yours because yours is a 4X4 and attaches to the transfer case where his has a tail section that attaches to his drive line. I would take his sensors as well but they should be plug and play with yours.
Old Apr 9, 2011 | 09:27 PM
autaurkhos's Avatar
autaurkhos
thnx a lot.i'l be back here for more info.this IS the best Dodge forum site i've found.
