Upper radiator hose
Old Apr 10, 2011 | 08:27 PM
samnbensdad's Avatar
samnbensdad
Default Upper radiator hose
02 SLT 5.9L
Has anyone used the Dayco upper radiator hoses (takes 2 due to the flange with the cap) on the 5.9? I am just curious whether or not is truly is a direct fit or if it needs to be trimmed.
I have a slight drip at the flange, it's so slight that it never makes it to the ground before evaporating. I'm not sure if it's the flange, hose, or the connection between the 2. I may just replace the it too.
Old Apr 11, 2011 | 09:31 AM
Dans01Durango's Avatar
Dans01Durango
I'd go with OEM cause they have a spring on the inside that keeps the hose from collapsing on itself. And get the stainless steel screw-type clamps instead of the spring ones.
