Tire Question:
Old Apr 13, 2011 | 12:56 PM
jaster's Avatar
jaster
Default Tire Question:
Currently I have mud tires on the Rango, they are worn down and I am wanting to switch to A/T tires. They are currently 35x-12.5-15. My question is, Would there be any issues if I went down to 33" tires, using the same rims? The price difference between 33" & 35" tires is significant.
Old Apr 13, 2011 | 12:59 PM
WhiteWidow00's Avatar
WhiteWidow00
No there won't be any impact other than having to re-calibrate the speedometer. Most tire shops can do this all you gotta do is ask because it will show you're going slower Han you are.
Old Apr 13, 2011 | 02:02 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
no issues w/ the rims, just the speedometer will need to be calibrated as widow said
Old Apr 13, 2011 | 07:07 PM
jaster's Avatar
jaster
Thanks for the info. I found that the selection for a direct replacement for my 35x 12.5 15, are kinda hard to find, The most I get are 2 or 3 choices depending on where I shop. From my understanding the last number being 15 is the rim size. What other size tires would fit on my Durango using this rim? The "D" is lifted and modified so that the 35s have no rubbing issues, etc.. I have been looking and I know the numbers i am looking up are the high-floatation tire sizes. Is there a metric number comparable to the the 35x/12.5/15 that is currently stamped on my tire that would fit my vehicle?
Old Apr 13, 2011 | 09:11 PM
MN_DeeDee's Avatar
MN_DeeDee
Try this website for size comparisons:
http://www.1010tires.com/tiresizecalculator.asp
Old Apr 13, 2011 | 10:00 PM
topdogcustoms's Avatar
topdogcustoms
what lift do you have ?
Old Apr 14, 2011 | 10:33 AM
jaster's Avatar
jaster
Great help guys. Thanks for the info. That 1010 tire chart just got added to my bookmarks. I decided to downsize to the 33" Goodyear Wrangler duratracs. It may look a bit goofy with the lift and the smaller tires, but I doubt the difference between 33" tires and 35" tires is going to be that noticeable. The lighter tire may give a little more mileage, a bit cheaper up front, and a little easier on the truck wear and tear.
Old Apr 14, 2011 | 12:05 PM
topdogcustoms
Jaster what lift do you have
Old Apr 14, 2011 | 01:22 PM
jaster's Avatar
jaster
I honestly don't know. The previous owner had the lift done. I should probably find out, but I never really thought about it.
Old Apr 14, 2011 | 01:25 PM
WhiteWidow00
Does it look like beefed up suspension components or does it look like the body is just lifted off the frame. My guess is you have a combination of a 2" T/S Lift and a 3" body lift. At least to my knowledge you require a total of 5" in order to fit 35" tires.
