ohh those o2 sensors
First off it is called the PCM not a pcu.
P0135 1/1 O2S Heater Failure
P0141 1/2 02 Sens Relay
The P0135 means the drivers side before the CAT is bad. Go get a DESNO sensor or NTK sensor. Bosch sucks! Also check connections.
P0141 is a bad relay in the PDC under the hood. Swap with one of the same number like the horn, if it goes away then replace the relay.
