Stereo is intermittent...
Old Apr 16, 2011 | 10:05 PM
nurseswim's Avatar
nurseswim
Default Stereo is intermittent...
i was hoping for some advice. i have an 02 Durango w/ factory stereo/CD + Infiinity speakers. the radio frequently does not work- all pre-sets work, functions work,clock, etc but, when on, there is no sound. can anyone advise? thank you
Old Apr 19, 2011 | 09:24 AM
jasonw's Avatar
jasonw
Site Moderator
This is in the wrong section, it belongs in the 1st Generation Durango (pre-2004 Durangos). I will move it there, where you should get a lot more responses.
Old Apr 19, 2011 | 10:41 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
do you have the factory infinity system in it? if so it sounds to me like your amp is on its way out, or you have a bad ground going to the amp
Old Apr 19, 2011 | 07:01 PM
rob[GL]'s Avatar
rob[GL]
Do CD's play without problem?
And I agree it could be the amp going out... Or just a bad ground.
I just installed a new stereo in my 2000 Durango and I had a simple problem with a bad ground.
Old Apr 19, 2011 | 08:11 PM
MAGIC84's Avatar
MAGIC84
Am I missing something? It looks like this post is in the 1st gen section or is this the corrected version?
Old Apr 19, 2011 | 08:21 PM
WhiteWidow00's Avatar
WhiteWidow00
MAGIC, it was moved to this section already LOL
Old Apr 19, 2011 | 08:30 PM
MAGIC84's Avatar
MAGIC84
I got it now. Then +3 try ground first....that sounds like the easiest starting point.
Old Apr 20, 2011 | 01:24 PM
winkie74's Avatar
winkie74
have you had the dash apart recently?
Old Apr 21, 2011 | 12:02 AM
hydrashocker's Avatar
hydrashocker
I was lost from the sart on this one????????????
Old Apr 21, 2011 | 12:39 AM
topdogcustoms's Avatar
topdogcustoms
Either you have a bad ground or + 1 ss your amp is going out check all connections
