oil pressure suddenly drops
Old Apr 23, 2011 | 02:04 PM
octaneforce's Avatar
octaneforce
Default oil pressure suddenly drops
i have a 2000 durango w/ the 4.7. when i first start driving it while its cold, the oil pressure gauge will suddenly drop to zero for a second, and then the check gauges light comes on. it only does this for a breif moment, and then everything goes right back to normal. i dont hear any strange noises and there is not a lack of power. it will do this two or three times until it is warmed up. any ideas? -thanks
Old Apr 23, 2011 | 02:27 PM
gr8scott72's Avatar
gr8scott72
Either oil pump or sending unit is going bad. Hope it's not your oil pump.
Old Apr 23, 2011 | 03:04 PM
hydrashocker's Avatar
hydrashocker
Sounds like the oil pressure sensor.
Old Apr 23, 2011 | 06:59 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 hydra, sounds to me like the sending unit if you were loosing oil pressure you would be hearing it
Old Apr 23, 2011 | 10:20 PM
octaneforce
i was also praying that its not the oil pump. how can i test if its the sensor/sending unit? would any of this show up if i hook it up to a scanner?
Old Apr 23, 2011 | 11:05 PM
shrpshtr325
THE ULTI-MOD
the best way to check the sending unit is to either replace it, or hook up a mechanical gauge and see what that does when the gauge on the dash drops
Old Apr 23, 2011 | 11:43 PM
hydrashocker
Or just replace it cause it's only like $15 bucks?
Old Apr 24, 2011 | 07:51 AM
shrpshtr325
THE ULTI-MOD
that was my first suggestion . . .
Old Apr 24, 2011 | 09:38 PM
octaneforce
okay. where is the sending unit located? do i have to take apart the dash? sorry to sound so newbish, its just not something ive done before.
Old Apr 24, 2011 | 09:58 PM
WhiteWidow00's Avatar
WhiteWidow00
No the sending unit is way easier to replace than you think. In fact its much like replacing an O2 sensor. The sending unit is located right by the oil filter, actually between the filter and the engine block.
Heres a diagram to help you ou where it's located at. Number 4 is pointing at it...
