A/C question
Old Apr 28, 2011 | 05:25 PM
mikesram's Avatar
mikesram
Default A/C question
Can someone point out the low side of charging the A/C? A picture or description of where to find it, I just changed out my condenser now I need to charge it up. BTW its a 2000 Durango.
Thanks!
Old Apr 28, 2011 | 05:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
your best bet is to have a shop do it, they will vacuum the system down to check for leaks and pull any moisture that may be in there out, and then charge it up w/ the correct amount of refrigerant and compressor oil, sorry i dont have a picture for you, but a/c systems DO require some pretty expensive equipment to work on
Old Apr 28, 2011 | 10:38 PM
hydrashocker's Avatar
hydrashocker
Should be on the compressor.
Old Apr 29, 2011 | 03:10 PM
mikesram's Avatar
mikesram
Thanks for the help. I'll let the shop charge it up.
