fuel delivery nobus code
Old Apr 28, 2011 | 11:55 PM
Randoodle23's Avatar
Randoodle23
Default fuel delivery nobus code
I own a 2001 4wd Dodge Durango and was on my way to work slowing down to a light hit the accell and engine quit! Engine cranks but won't start turning the ign. on all the pre strt cks. complete the low fuel light comes on also gas gauge does not register and ck. gauges message comes on. cannot hear pump cmon when ign switch is in ON pos. whatever happened no power to fuel pump or gauge. checked all the fuses relays etc. they seem to be fine. Odometer flashes 3 times and nobus code comes up. fuel pump, filter, computer were all replaced in October 2010. Anybody have a clue what the problem may be ??????????
Last edited by Randoodle23; May 2, 2011 at 10:40 PM. Reason: Incomplete Information
Old Apr 29, 2011 | 09:21 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
a couple of problems here
1) you did not read this thread please read before posting in this section
2) you did not indicate which year and driveline your truck is.
Old May 2, 2011 | 10:44 PM
Randoodle23
sorry my bad, completly spaced putting year and model of truck it has been corrected. Again my apologies !
Old May 4, 2011 | 09:04 PM
hydrashocker's Avatar
hydrashocker
Sounds to me like your computer (PCM) went out. You can get a new one on ebay for like $200 bucks pre-flashed for direct install. WhiteWidow00 knows of a place that sells OEM ones that are New and not rebuilds for like $50 bucks more.
But again, you want to get it pre-flashed with your vehicle info and they are shipped to you for direct plug and play install.
Old May 4, 2011 | 09:08 PM
topdogcustoms's Avatar
topdogcustoms
+1 Hydra
