Broken Shock Bolt
There is a shoulder on the back of the bolt sticking out of the threaded control arm, but I can't get good enough access to it in order to get vise grips onto it. I drilled the bolt and put an easy out into it and ended up breaking the easy out. Not sure where to go next, guessing maybe pull off the control arm and machine it out or replace it. Anyone got any other suggestions?
Thanks
Thanks
All of the part numbers for the control arms were just added to a post at the DOC. I suggest you check it out for yours and start looking for a replacement.
http://www.durangoclub.com/forum/viewtopic.php?t=13777
IndyD
IndyD
