Durango Stalling.
Old May 12, 2011 | 09:31 PM
justin101's Avatar
justin101
I dont know what type of spark plugs are used, its too late to do any work now but i will look tomorrow at the plugs more carefully and actually take the distributor off tomorrow to look at it. Thanks for all your help thus-far though.
Old May 12, 2011 | 10:01 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
low idle stumble/stalling is very often a simple bad battery, do you have any idea how old the battery is? this is a very common symptom of a bad battery being that it will crank fine, and run fine w/ a foot on the gas, but once you let up the battery doesnt have enough voltage to keep her running, the pcm goes WTF!?!?!?!?!?!?!!!!!!!!!!! and shuts off the engine.
Old May 13, 2011 | 09:35 PM
justin101's Avatar
justin101
Well their are two 12 inch subs in it running at 900 watts and im not sure how old the battery is. But my battery gauge always stays in the center and even if i play my music at night, the lights dont even dim.
Old May 13, 2011 | 11:48 PM
shrpshtr325
THE ULTI-MOD
battery life on these rigs is about 4 years, probably less in your case
Old May 14, 2011 | 12:29 AM
justin101's Avatar
justin101
Well i put a new IAC in and it seems to be okay now. Drove it for about 20 to 25 minutes and no stalling, stumble, or anything like that. If i have the battery tested by like Auto Zone or another parts store, they should be able to tell me if its good or not right?
Old May 14, 2011 | 08:14 AM
shrpshtr325
THE ULTI-MOD
thats a good place to start, however the load tests are not 100%, especially for these trucks and the picky pcm, if is very possible that the IAC was your only problem, however i didnt include that bc someone else already had.
Old May 14, 2011 | 11:12 AM
justin101's Avatar
justin101
Well I've been driving around for awhile now and its still good, the motor runs a little better now too. So i guess just a bad IAC. Thanks for all your help though.
Old May 14, 2011 | 01:03 PM
topdogcustoms's Avatar
topdogcustoms
glad you fixed it
Old May 15, 2011 | 12:35 AM
hydrashocker's Avatar
hydrashocker
You should pull the throttle body and give it a good clean job and reset the PCM. You should also pick up a new battery.
