Headlight issues
Old May 19, 2011 | 12:11 AM
TOMMYB's Avatar
TOMMYB
Default Headlight issues
Does anyone know where the headlight relay is on an 02 Durango. The headlights, fog lights, & interior lights are all inoperative. Tried a new headlight switch but still no lights. I have looked in both fuse panels and found nothing.
Old May 19, 2011 | 01:30 AM
IndyDurango's Avatar
IndyDurango
The relay is in the PDC under the hood. It is labeled under the lid of the PDC.
IndyDurango
Old May 19, 2011 | 09:37 AM
TOMMYB's Avatar
TOMMYB
Hey Indy. I checked the PDC twice and didn't see a relay for the headlights. I found the relay for the fog lights and the breaker for the interior lights. The breaker for the interior lights is a 40 amp, any possibility that the headlights are tied into the interior light breaker? I looked at the breaker and it looks good.
Old May 19, 2011 | 07:57 PM
WhiteWidow00's Avatar
WhiteWidow00
There are breakers under the hood in the PDC and are labeled LT HD/LP and RT HD/LP. They are 15 AMP IIRC and this is where I would start. I would say since you don't have all of those that you either got a defective unit or it's something in the wiring that's not getting power because there are all separate relays, breakers, and fuses for each of those problems you state.
Old May 20, 2011 | 01:41 PM
TOMMYB's Avatar
TOMMYB
Thanks Widow. I will check again. I just need more time to work on it instead of trying to tinker with it after working 14 hours.
