Turn key and nothing
Old May 26, 2011 | 05:46 AM
mikegrasso's Avatar
mikegrasso
Default Trouble shoot suggestions?
Regarding the trouble shooting. Where should I look next? It did start one last time, managed to get it home to my driveway. Relieved! Considering that it did start after a couple days of sitting, can I eliminate fuses, etc.? Note; It's back in my driveway and refusing to give me even a peep on ignition, no noise whatsoever. Regards,
Old May 27, 2011 | 01:10 PM
hydrashocker's Avatar
hydrashocker
I would go to the PDC and see if you are getting any power to the starter relay. You could also check the Neutral/Park relay.
Old May 27, 2011 | 04:19 PM
Kensai's Avatar
Kensai
Just a thought, since you have a 99 model, you may want to check your crank sensor and/or the big 150 amp fuse on the fuse block that may be causing these symptoms. These two issues are well documented for 99 models in this forum.
Old May 29, 2011 | 08:08 AM
mikegrasso's Avatar
mikegrasso
Smile Fixed It
Thanks for all that responded.
It was in the coupler connector to the starter, it appeared to be fine on inspection but was not connecting internally. Posting this follow up for reference's sake. Thanks again to all responses.
