1999 Durango SLT
Old May 26, 2011 | 03:34 PM
wrenchman's Avatar
wrenchman
I have a '99 with only 63,500 miles. Check engine light code: P0720. Can I fix it myself? Rear wheel sensor mounted on rear differential housing? Please advise me.
Check engine code: P0720. Output speed sensor. Can I fix it myself? Is it connected to the rear diff? Have been getting irregular idle from time to time. Please advise me. Maybe dirty connector?
Last edited by shrpshtr325; May 26, 2011 at 04:07 PM. Reason: double post is unnecessary
Old May 26, 2011 | 04:06 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
P0720-LOW OUTPUT SPEED SENSOR - RPM ABOVE 15 MPH
replace the output speed sensor on the transmission, its an easy swap and a $20 (about) sensor, should take longer to drive to the store and pick it up than it does to change (5 min MAX to change)
also have a rag ready a little bit of trans fluid will likely drip out, not enough to catch or affect the fluid level, but enough that you will want a rag handy
Old May 26, 2011 | 07:16 PM
wrenchman's Avatar
wrenchman
Thank you shrpshtr325. The part is $17.00 Can you tell me where on the x-mission the sensor is located? From crawling underneath. Also, I added about a pint of fluid to bring things to normal. Don't think that was the problem.
Old May 27, 2011 | 08:18 AM
shrpshtr325
THE ULTI-MOD
the sensor is on the drivers side of the transmission tailshaft, on my old truck it was the only sensor under there so you cant miss it.
