No head lamps / dome lamps
Old May 26, 2011 | 03:50 PM
BD1718's Avatar
BD1718
Default No head lamps / dome lamps
My 2002 Durango SXT just lost power to the Head Lamps and Dome Lamps, all other lights are in working order. I cant find a fuse for these lamps in the engine compartment or in the fuse panel inside car by the drivers door.
Anyone ever see anything so crazy??
Old May 26, 2011 | 04:24 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would start by checking fuses for the switch and the interterior lights/headlights here is a pdf with the fuse blocks and the labels for what is what
http://www.mediafire.com/?q3qg27o4gwoirii
http://www.mediafire.com/?3yse6uo6l9jgirh
and a picture
(that image is the fuse block door from the drivers jamb of my 2002)
then i would check the grounds for both systems
as well as the connector on the back of the headlight switch and the plugs at the CTM, if one of them worked loose it could cause issue, although i would expect these to be more intermittent problems
Old May 28, 2011 | 10:05 AM
BD1718's Avatar
BD1718
Fuse was good, I'm thinking the rain is causing some strange problems
