broken durango
Old Jul 8, 2005 | 03:16 AM
jimmi g's Avatar
jimmi g
Default broken durango
'98 Durango. Put the key in and turn to on (not start) all lights come on (normal) turn to start and all power is gone (lights out). Turn key back to off and there is a 'click' from the glove box area. Turning the headlights off and on repeatedly seems to reset this problem, but can't start the SUV. It seems like it may be a security system problem.
Any thoughts?
thanks
Jimmi
Old Jul 8, 2005 | 01:54 PM
Last Of The R/Ts's Avatar
Last Of The R/Ts
Default RE: broken durango
Well I know even if you have a copied key without the chip, the truck will start but it will also turn off after about 5 seconds. You are using an original or programmed key, correct?
Old Jul 9, 2005 | 04:17 AM
Dave in LB's Avatar
Dave in LB
That's an interesting point. i'm thinking it could be a solinoid for the starter or something that has gone out and is holding the system down. Maybe a bad ballast or relay. Electrical technical is not really my forte.
Old Jul 10, 2005 | 11:43 AM
rcs426's Avatar
rcs426
first of all check the battery ! there is not a chip in the key for a 98 D. If the securty sys. is being the problen try on locking the pass. side door with the key thats how to reset the securty sys.
Old Jul 10, 2005 | 04:47 PM
Spedray's Avatar
Spedray
Sounds like you have a correded battery cable running to your stater soleniod. Had the same thing happen to my Jeep last month. The tetminals where nice and clean but inside the plastic it was all correded and couldn't get a good charge.
