anyone know brakes?
Old Jun 10, 2011 | 12:15 AM
tdmichel's Avatar
tdmichel
Thumbs down anyone know brakes?
OK here the deal My wife has been complaining to me the past week that here wheel has been making a sqeaking sound when she braked. ok no problem I headed down to the auto zone got a set of pads and figured a easy fix.... Wrong nothing wrong with the brakes what i found was the sqeaking sound was comming from the outside hardwear spring rubbing on the hub.. After taking it all apart I found that the mounting pin on the bottom was striped on the (i think its called) steering knuckle. here is my problem what to do? i cant put back together with out the pin in place but i cant get pin to bite.. tapping hole bigger is out of question on on corner of hole there is only a 1/8in to work with dont thnk it would work. so here i sit 10:30 thursday night looking for help..any ideas would be great.
Old Jun 10, 2011 | 07:56 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
im assuming your truck is between model years 98-03, and if it is the stock bolt you have 3 options,
1) larger caliper bolt
2) helicoil the exisiting bolt
3) new steering knuckle
also this belongs in one of the sub sections, 1st generation if i guessed right on the year
https://dodgeforum.com/forum/dodge-d...s-section.html
Old Jun 10, 2011 | 02:11 PM
srch4me's Avatar
srch4me
my suggestion is to helicoil it... its the cheepest way to do it... its what i did to my truck and its worked perfectly and it takes maybe an hour... its easy too
Old Jun 10, 2011 | 05:11 PM
shrpshtr325
THE ULTI-MOD
i agree, as long as it hasnt been repaired before, if it has your SOL and need a new knuckle
Old Jun 10, 2011 | 09:57 PM
srch4me's Avatar
srch4me
just make sure when you do it you take your time... be patient... it took a couple times before i got the coil part in straight and the bolts would fit... so take your time, be patient and dont rush it... i just did this about 2 months ago on my drivers side knuckle.
