P1391- replaced sensor, made it worse
I pulled a P1391 code to replace CMP, or worse that the timing chain jumped or stretched. Searched around DF and found that most people that pulled this code replaced the sensor and nothing about the timing chain. As soon as I installed the new sensor the engine had a rough idle and I had to keep my foot on the throttle to keep it running. As it idles it hesitates, skips and knocks and the exhaust smell is stronger. 4 months ago my distributor, cap, and rotor along with plugs were replaced. I'm pretty sure the wires were not replaced. When I step on the gas rpm's rev up but I can't go forward or backwards.
Any ideas or feedback would be appreciated.
did you reset the PCM when you replaced the sensor?
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shaddow for 40 full cold starts.
