Power windows not working 2002 durango
Old Jun 24, 2011 | 04:55 PM
evan grant's Avatar
evan grant
Default Power windows not working 2002 durango
None of my windows are working,i dont seem to have power at the drivers side switchs,fuses/relays checked ok,so i replaced the ignition switch still nothing.any ideas?thanks.
Old Jun 24, 2011 | 10:32 PM
topdogcustoms's Avatar
topdogcustoms
do you have power at the relay
Old Jun 24, 2011 | 11:29 PM
evan grant's Avatar
evan grant
yes i have power at the relay
Old Jun 25, 2011 | 12:12 PM
topdogcustoms
it sounds like a driver side switch is bad are you sure there's no power at the switch
Old Jun 25, 2011 | 01:34 PM
samnbensdad's Avatar
samnbensdad
My undestanding is that each individual window control is wired through master control (driver control). So, if nothing is working then you have either a faulty relay &/or fuse (or a mysteriously grounded or fried wire). You stated that the relay was ok; did you actually swap it out with another relay? That is the easiest/best way to check?
Are you having any other electrical problems like alarm not activating, doors not locking, weird stuff with you instrument cluster, etc...?
Old Jun 25, 2011 | 02:31 PM
evan grant's Avatar
evan grant
Yes i swapped out the relay and fuses with others,still no power.also swapped out drivers master switch no difference.
Old Jun 25, 2011 | 02:52 PM
samnbensdad
It may be time to get out the multi-meter and start checking wires... ugh
Old Jun 26, 2011 | 11:21 AM
WhiteWidow00's Avatar
WhiteWidow00
It sounds to me there is a power receiving problem in wiring somewhere between the relay circuit and the driver side door control. Like samnbensdad said, you're going to have to break out a multi-meter and find out exactly where the break in the line is, or what's causing you to not receive power at the controls.
Here's a wiring diagram that should help you out that shows leads to everything. HTH
Old Jun 27, 2011 | 02:54 PM
hydrashocker's Avatar
hydrashocker
+1 Widow
Old Jun 29, 2011 | 03:08 PM
HunterN's Avatar
HunterN
All of your window motors could have went out at once! Although its highly unlikely
