Dodge durango p1732 code, i need help
Old Jul 10, 2011 | 02:31 PM
ELIUSOSA's Avatar
ELIUSOSA
Default Dodge durango p1732 code, i need help
I have a 2000 dodge durango 4x4 d and i have the code p1732, which is what is wrong ?????? The bus is only in the morning when it is cold in the morning the transmission will not apply, the change in speed and arrnca then gives you more eprolema no, that is the code p1732?? That is about it do??
Old Jul 12, 2011 | 01:03 AM
master tech's Avatar
master tech
Site Moderator & Tech
This should be moved to the durango section.
Symptom:
P1732-UD PRESSURE SWITCH SENSE CIRCUIT
When Monitored and Set Condition:
When Monitored: Whenever the engine is running.
Set Condition: This DTC is set if the UD pressure switch is in the wrong state for the
current gear. For example, this code would be set if the UD pressure switch came on while
the transmission was in second gear.
POSSIBLE CAUSES
RELATED RELAY DTC’S PRESENT
INTERMITTENT WIRING & CONNECTORS
UD PRESSURE SWITCH SENSE CIRCUIT OPEN
UD PRESSURE SWITCH CIRCUIT SHORT TO GROUND
TRANSMISSION RELAY OUTPUT CIRCUIT OPEN
UD PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
UD PRESSURE SWITCH
TCM (UD PRESSURE SWITCH)
TEST ACTION APPLICABILITY
1 Check the transmission fluid level per the service instructions. Check fluid condition.
Inspect the transmission. Look for leaks or other physical damage.
Connect a battery charger to the vehicle.
With the DRBIIIt, read the engine DTC’s. Check and repair all engine DTC’s prior
to performing transmission symptom diagnostics.
With the DRBIIIt, read Transmission DTC’s. Record all DTC’s and 1 Trip Failures.
Note: Diagnose 1 Trip Failures as DTC’s (Hard codes)
Visually inspect connectors and wiring harness. Repair as necessary.
Perform the Shift Lever Position Test. If the test does not pass, refer to Symptom test
for P-0705 Check Shifter Signal.
For Speed Ratio DTC’s, record all CVI’s.
Most codes set on start up but some codes must be set by driving the vehicle.
Perform this procedure prior to Symptom diagnosis.
Old Jul 12, 2011 | 02:11 PM
ELIUSOSA's Avatar
ELIUSOSA
Thanks, Thanks, Thank you for reply my message, thanks for help me.
