I think my problem is the lifters, on a cold start I get noise for about 10-15 seconds, on the 01 with 4.7 I believe I could have a clogged passage that's gets oil to the lifters, where are those located on the 4.7? thanks
Napa Gold by Wix
I am running M1 5w30 synthetic right now I have ran a qt of Rislone in the crankcase, then changed the oil again, did not really help. I checked the level and its on the full mark.
in the manual it says to use 5w30 for the 4.7? would 10w30 work better?
Thanks, I will have to switch it out to 10w30 do you think the Napa gold filters are good and have a good anti-drainback valve?
