Car shutdown while driving....
Old Jul 11, 2011 | 06:55 PM
rchoungping's Avatar
rchoungping
Default Car shutdown while driving....
Hi !
I bought a 1998 dodge durango 5.9L recently for cheap and 2 days ago, while driving my car shut the hell down !!! for no reason. I step down the emergeny lane and wait for approximatively 20 mins till the engine start again. And now It happens all the time !!!! I don't know what to do !
Can anyone help me !
Old Jul 11, 2011 | 08:57 PM
adukart's Avatar
adukart
It sound like something electrical, like something is overheating and shutting down. Maybe PCM? Does it just shut down or is there something that precedes it? When it shuts down does it just die or does it do something like sputters and dies? Any particular outside air temps that it happens faster or later in your drive? Could you please give some more details please
Old Jul 11, 2011 | 09:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
try this, next time it shuts down take a bag of ice and place it on the PCM (electronic module on the passenger side fender well) and try starting the truck, if it starts your PCM is overheating and needs to be replaced, this is a common issue on dark colored trucks from 98-00
Old Jul 12, 2011 | 12:03 AM
hydrashocker's Avatar
hydrashocker
+1 Sharps
Also could be a fuel pump getting hot because you are low on gas.
Old Jul 12, 2011 | 12:22 AM
adukart's Avatar
adukart
+2 for shrps
Old Jul 12, 2011 | 01:59 PM
rchoungping
Thank you everyone for your answer !!.
First of all, yesterday I talked to a friend of mine and said maybe it is the ASD relay... I don't what it is or it does . Can anyone explain to me ?
Second, I'll tryshrpshtr325 advise next time if it works.
Can a scan tool detect the overheating PCM or not ?
Tahank you !
Old Jul 12, 2011 | 03:45 PM
shrpshtr325
THE ULTI-MOD
ASD is auto shutdown relay, i believe it is a failsafe for accidents and such that it will open (open the circuit, lol) so that the fuel pump and ignition dont keep running,
either way if its bad the truck wont start, swap it with one of the same number
and no a scantool cannot detect PCM temperature or if its overheating.
Old Jul 12, 2011 | 07:08 PM
rchoungping
OK thanks for the update !!
I'll try to swap to another one !
This morning, I drove my car for about 10 miles and no exception the car stopped. I could restart the car after 10 min. I try to apply a bag of ice and try starting the car. It didn't work either.
I'll go the dealer store to see if they can check the PCM before buy a new one.
Otherwise, google and this forum are my friends
Old Jul 13, 2011 | 07:24 PM
hydrashocker
You are supposed to put the bag of ice on the PCM before you drive it and see if it shuts down. This keeps it cool and doesn't allow it to overheat.
Old Jul 13, 2011 | 07:42 PM
atthewmartin114's Avatar
atthewmartin114
change the coil. there known for being bad with the 5.2 and 5.9 the brake down then they get hot and you can pick one up really cheap at advanced auto and you dont need to pull the old one off to check this you can do it right then you actually have a stall case. pull the plug and the coil wire and plug them in to the new one and see what happens
