CTM Fuses
Old Jul 13, 2011 | 10:46 AM
Rigione's Avatar
Rigione
Default CTM Fuses
I have been having problems with interior lights flashing and remote door locks not working and rather then their being a pleasent chime when the keys are left in the ignition there is a buzzing noise. I had the battery replaced and think someone was messing round in the fuse box because shortly after that the remote door locks stopped working. I assumed it was the battery in the key fob and replaced it but the door locks still didn't work. Short of the door locks, flashing interior lights when the door is open and key is off, and chime everything else works great. I noticed that there is only one fuse in the CTM slot. Should there be a fuse in each CTM fuse box slot? I only have a fuse in CTM B. Should their also be one in CTM A slot? Thanks for your help.
Old Jul 13, 2011 | 11:27 AM
Rigione's Avatar
Rigione
Default CTM Fuses 2002 Durango SLT
Old Jul 13, 2011 | 12:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i have a 20 amp fuse in both CTM A and CTM B, so yes there should be a fuse in there, however idk how a missing fuse would cause those problems definitely get it replaced and see what happens
Old Jul 13, 2011 | 07:42 PM
hydrashocker's Avatar
hydrashocker
+1........I would install the other fuse and reset the PCM. https://dodgeforum.com/forum/1st-gen...ine-light.html
