1998 durango fan speeds
Old Jul 18, 2011 | 06:38 PM
bando598's Avatar
bando598
Default 1998 durango fan speeds
My blower fan was only working on the 3 low speeds. I replaced the blower motor relay and it worked for a few days, then it blew out again. So I replaced the blower motor resistor and the relay and it worked for 2 weeks. Wife just came home and said the relay blew out again. So, again it only works on the 3 lower speeds. Does anybody have any ideas on what the heck is going on? Any help would be greatly appreciated!! (married men will know what I mean)
Old Jul 18, 2011 | 07:21 PM
samnbensdad's Avatar
samnbensdad
You should take a close look at the wires leading to the resistor. Sometimes when a resistor goes bad it will overheat and damage the connector or even melt some of the wires.
Old Jul 19, 2011 | 06:59 PM
hydrashocker's Avatar
hydrashocker
Look at the harness on the resistor for corrosion or burned connections. If you find that it is then you will need to go to a junk yard and get a new one and wire it in or get the replacement kit (much better than the OEM) from the dealer.
