air problem
Old Jul 29, 2011 | 05:34 PM
hydrashocker's Avatar
hydrashocker
Brake Booster:
Model year 1998
Brake Booster Check Valve: 04796355
Brake Booster Grommet: 04883813AA
Model year 1999
04796355
04883813AA
Model year 2000
05016730AA
04883813AA
I don't have any part numbers for the switch side, in fact it could be the switch it's self. I've disassembled one put it back together and the insides to them look like ant homes full of valleys. One of those could go a check inside the switch valve body, but I didn't follow each line to ensure?
*EDIT*
There is a TSB on this issue as well, but for a different year? TSB 24-01-96
http://dodgeram.info/tsb/1996/24-01-96a.htm
But I wonder if it would help?
Old Jul 31, 2011 | 12:18 AM
IndyDurango's Avatar
IndyDurango
Thanks HS. I'll post my results of vac experimentation.
IndyD
Old Aug 4, 2011 | 08:49 PM
Tibodo6's Avatar
Tibodo6
Ok I finally got it it's the doors that change the air direction for some reason they are to stiff for the acculator to shut them I whatched try but the plastic arm just moves around the door arm so I put a little hose clap on it and it will open them but it has a hard time closing them and that plastic arm is now broken so I need to find one of those with out knowing the name Good Times all around
Old Aug 5, 2011 | 12:02 AM
hydrashocker
It's called the actuator. Could need just a new one.
Old Aug 5, 2011 | 04:55 PM
Tibodo6's Avatar
Tibodo6
Yeah probably but I know I need that plastic arm that gos from the actuator arm to the doors rod I don't know the name of that part I broke one of the arms that clamp on the doors rod and thr doors are still really stiff not real sure how to either grease or loosen
Old Aug 6, 2011 | 04:18 PM
hydrashocker
Spray some lubricant on them, just use an oil and not something like WD-40.
This might show you the part name:
Old Aug 9, 2011 | 07:07 PM
Tibodo6's Avatar
Tibodo6
That is so close but it's the circulation actuator I'm guessing the name it's for the two doors for vents and floor I wish I would have read your post earlier cuz I sprayed wd40 but I put that three n one oil on and in the gears today thanx for you help. I have a pic but I don't know how to get it on here from my iPhone
Old Aug 12, 2011 | 02:39 PM
Tibodo6's Avatar
Tibodo6
I called dodge it's the mode door actuator apparently they had that $50 but the plastic conector they said was discontinued so I'm supposed to play MacGyver and build somthing
Old Aug 12, 2011 | 11:18 PM
Tibodo6's Avatar
Tibodo6
http://www.partswebsite.com//stores/...sT/TG98100.gif
Old Aug 13, 2011 | 02:27 PM
Tibodo6's Avatar
Tibodo6
Ha ha found it simple as mode door lever $3 give or takenow I need the name for the over head fan the ac thats in the head liner kids put their toy or something in there and destroyed it it hard to find with no name
