Last edit by: IB Advertising
Browse all: Cooling System
- Dodge Ram 2nd Gen How to Flush Radiator Coolant
Step by step instructions for the do-it-yourself repairs.
Radiator flush
HI Guys, I just bought a 99 Durango with the 5.9 V8. Runs nice and dosen't overheat but the guy I purchased it from filled the radiator with water(standard tap). The water turned all rusty(go figure). Anyway, what is the best way to drain flush and refill? Also, after the drain and flush, how much water is still trapped in the motor? I ask that because I am trying to figure out the mix for the coolant.
Thanks
Thanks
Thanks
Thanks
givin the situation you should( if you have not planned already) replace the t-stat too ... Do yourself a favor and buy plain generic aspirin...take 1, and put the thermostat in boiling water to open it... pull it out with pliers, and hold the aspirin in the gap of the thermostat opening to hold it open... as it cools, it will clamp on the aspirin... install it like that, and when you refill the cooling system, all the air comes out the top radiator hose... start it and top it off... as it runs for the first couple minutes, the aspirin will dissolve and the thermostat will close until it heats up!
hope that helps...
