Engine issue, need advice
Old Jul 29, 2011 | 03:27 PM
Shawn1224's Avatar
Shawn1224
Default Engine issue, need advice
I have 1999 Dodge Durango (5.2) and about a month ago I had been hearing a rattling sound coming from the engine whenever I’m pressing the gas and it goes over 55mph. I didn’t think much of it because it was only happening every now and then and if I let off the gas some the sound would go away. Well, recently my wife was driving the car and after she stopped to pay the toll when she was coming off the freeway, the car wouldn’t move when she pressed the gas. According to her she said she felt nothing when she pressed the gas and hadn’t heard any knocking sound prior to that. Only that the engine light came on. After it happened, the engine was still running so she turned it off since the car wouldn’t move. Since then, the engine hasn’t started back up, it turns over but refuses to crank up. I have very limited funds so I’m trying to figure out if it’s worth it to fix.
Do you think the engine is locked up?
Old Jul 29, 2011 | 05:28 PM
hydrashocker's Avatar
hydrashocker
Did the motor rev up like it was trying to move or did it just not do anything?
Old Jul 29, 2011 | 07:14 PM
Shawn1224's Avatar
Shawn1224
No revving, it did nothing.
Old Jul 29, 2011 | 07:24 PM
topdogcustoms's Avatar
topdogcustoms
how many miles does it have
Old Jul 30, 2011 | 12:51 AM
Shawn1224's Avatar
Shawn1224
Right around 120,000
Old Jul 30, 2011 | 01:29 AM
Biff85ta's Avatar
Biff85ta
Do you have spark? How about fuel?
Old Jul 30, 2011 | 03:11 AM
topdogcustoms
have you checked for fuel pressure sounds like a bad fuel pump
Old Jul 30, 2011 | 09:03 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 on the fuel pressure, you should also be able to hear it prime when you turn the key on
Old Jul 30, 2011 | 09:23 AM
Shawn1224's Avatar
Shawn1224
brand new spark plugs and wires. new rotor, distributor cap and ignition coil.I had a guy check it out and it's getting spark, fuel and air but it still won't turn over.he said it might be the timing but he want sure.
Old Jul 30, 2011 | 10:19 AM
shrpshtr325
THE ULTI-MOD
what is the fuel pressure while cranking?? i believe it should be between 47 and 51 psi
