bypassing window lockout switch
Old Aug 3, 2011 | 06:39 PM
DomsDodgeDingo's Avatar
DomsDodgeDingo
Default bypassing window lockout switch
My windows in my 2000 Durango aren't working. Only from the drivers switch. I believe it is the lockout switch. Can someone please give me a detailed description on how I would go about bypassing it? THANKS
Old Aug 4, 2011 | 01:27 AM
IndyDurango's Avatar
IndyDurango
No bypass, replace or R&R the existing one.
IndyD
Old Aug 4, 2011 | 09:11 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
wrong indy
see this post
https://dodgeforum.com/forum/2439583-post8.html
from this thread
https://dodgeforum.com/forum/1st-gen...r-windows.html
Old Aug 4, 2011 | 10:36 PM
IndyDurango
Grrrrrr.
Really?
Your "solution" leaves the system in an abortion-like state with "the doors as if they are unlocked all the time."
I guess if one doesn't mind redneck engineering, jumpers here and there, and a short years later leaving their Durango a burning hulk on the side of the road, go for it.
Otherwise, replace or R&R the existing one. For the time and trouble to do all in the links, I could swap out the switch probably 10 times and be done with it knowing I don't have to worry about any of this again for another decade.
I think we are back to the, "jut because you can doesn't mean you should" type of situation. I bet we could cut the top of of the Durango and create a convertible too. And let's do it using a tile saw and a chisel. Just sayin'.
Really.
IndyD
Old Aug 5, 2011 | 12:21 AM
hydrashocker's Avatar
hydrashocker
LOL
Well he did show him how to bypass it, but he didn't say it would work the same......
Old Aug 5, 2011 | 12:26 AM
adukart's Avatar
adukart
Really.
IndyD
LMAO
Old Aug 5, 2011 | 02:17 AM
IndyDurango
Thanks, I'm here all week.
Old Aug 5, 2011 | 05:19 PM
DomsDodgeDingo
Ok, so replacing the the entire master switch would solve the problem instead of bypassing it? So could I find one at a junk yard and use it?
Old Aug 5, 2011 | 08:12 PM
adukart's Avatar
adukart
Yes you can
Old Aug 5, 2011 | 08:36 PM
shrpshtr325
THE ULTI-MOD
yup a junkyard part is the cheapest way to do it correctly
and indy, as hydra said i never said it was a good idea, just that it was possible, and yes it does leave the windows in an unlocked position, however for those of us who dont have kids that is not a concern, its it technically correct? nope, of course not, will it work if you cant find the part or until the replacement comes in? apparently yes.
