When can a new PS Reservoir for 01 Durango 4.7 be purchased?
Old Aug 17, 2011 | 12:38 PM
jim1999's Avatar
jim1999
Default When can a new PS Reservoir for 01 Durango 4.7 be purchased?
I have a 01 Durango w/ 4.7 4x4 I need a new plastic resevoir for the power steering pump, I have checked Dealer, AZ, Advance, Napa,Oreilly, no one has them is there a company that makes them aftermarket? also I was going to rebuild my PS pump while I have it off, is a seal kit basically all there is too a rebuild? any help appreciated!
Old Aug 18, 2011 | 04:15 PM
hydrashocker's Avatar
hydrashocker
Never just seen the plastic reservoir.
The "Seal Kit" comes the seals needed for rebuild.
A "Pump Kit" comes with other parts and the seals for rebuild.
Old Aug 18, 2011 | 09:21 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
keep in mind on the 4.7 if you pull the pulley off the pump you need to replace it, it cannot be reused (as per the factory service manual)
also check rockauto for the reservoir
Old Oct 10, 2012 | 10:30 AM
goshox93's Avatar
goshox93
Default Did you find one?
I am changing out my PS pump and after removing the reservoir I found that the screen is loose and floating inside. I bought the pump with the pulley attached but also tried to find it with the reservoir and could not except at the dealer for 3x the cost. It seems like since everybody sells it w/o the reservoir and the screen doesn't appear to be serviceable you should be able to buy it separately right?
Old Oct 10, 2012 | 11:21 AM
srch4me's Avatar
srch4me
If you can't find one just get a inline filter
Posted from Dodgeforum.com App for Android
Old Oct 10, 2012 | 06:03 PM
Old_School's Avatar
Old_School
The only way to get a new reservoir is to buy a pump with one on it.... rockauto has them in stock.
