Check Engine light on....
Old Aug 17, 2011 | 08:34 PM
harleytech's Avatar
harleytech
Question Check Engine light on....
It say's , PO456 Evap. Emissions Leak (Small Leak Detected) Fuel cap maybe ?
anything else it could be...? Thanks..
Old Aug 17, 2011 | 08:43 PM
Tshane72's Avatar
Tshane72
I would start with the Fuel cap..seeing as how it's cheap...get a new cap, reset the PCM and see if it comes back on....if it comes back on...might be the Evap canister hoses under the truck....
Old Aug 17, 2011 | 10:33 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 on the gas cap, you can test this by either pulling aplastic bag tight over the gas cap, or coating the oring on the gas cap with vaseline to improve the seal short term.
also check the FAQ thread for the DIY on replacing the hoses to the charcoal canister.
Old Aug 18, 2011 | 09:26 PM
harleytech's Avatar
harleytech
As Alway's , Thanks for the info...I'll get the gas cap and go from there...
Old Aug 22, 2011 | 08:01 PM
harleytech's Avatar
harleytech
Well I didn't get the cap yet, But I did crawl under the vehicle and found 1 hose to the canister dry-rotted so I replaced them all...Maybe that was it...? I'm still gonna get the gas cap friday tho...Later....
