98 Durango
Old Aug 25, 2011 | 05:14 PM
docdrewski's Avatar
docdrewski
Default 98 Durango
So this is a long question concerning my 98 Dodge Durango. A few days ago I was driving home and just a few blocks from home my car overheated a little. I stopped and let it cool down and then drove home very slowly. When I parked the car in the garage and got out I noticed coolant on the floor and light steam coming from the engine. After letting it cool off I checked the coolant overflow and it was empty. I filled it up and when I started the car the battery was dead. I jump started it and let it run for a few minutes, looked for leaks, but then it overheated again. After talking to a friend he suggested I changed the thermostat, so I did. It was still dead so I jumped it again, but this time it would not stay running unless my foot was on the gas and it still overheated. I should also add that while it was running the last time and I was looking under the hood for leaks I could feel water spraying and that my AC quit working a few days before. Anybody got any clues.
Thanks
Old Aug 25, 2011 | 06:01 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
Try posting in the Durango section for more help
Old Aug 25, 2011 | 07:49 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Durango section,
FF
Old Aug 26, 2011 | 09:16 AM
bigred_84's Avatar
bigred_84
Check the oil and make sure there isn't water in it. If so you might have a blown head gasket.
Old Aug 26, 2011 | 12:28 PM
ccthomp's Avatar
ccthomp
Had almost the same prob with mine not running and I swapped the batt out overheat issue IDK but it not running could be anything, try putting a new battery in and see how that works.
Old Aug 26, 2011 | 01:15 PM
adukart's Avatar
adukart
Try to pin point where the water is coming from, look closely around the water pump this is the most likely cause. Also sounds like a bad battery, have it load tested (I believe oriellys does this for free) to see if you need a new one. It could also be a bad connection, I just got done with that on mine wed, it wouldn't start had to jump it and it would die when I tried to drive it. It was only a little corrosion, I have not had the joy of working on A/C so some one with experience might chime in.
Old Aug 27, 2011 | 01:44 PM
hydrashocker's Avatar
hydrashocker
Also could be your battery temperature sensor under the battery.
As for cooling issues, find the leak and do a compression test.
