Transmission fluid, help!
Old Aug 25, 2011 | 06:41 PM
Mechaniczman's Avatar
Mechaniczman
Default Transmission fluid, help!
As some of you know my truck leaks everything! Its a 1999 Dodge Durango SLT V8 Magnum $X$ with 240,000 miles and there is transmission fluid covering the entire transfercase and is a drip were it conects to the transmission. The manual calls for Mopar ATF+3 Automatic transmission fluid. But i have no idea were to buy it at i went to advanced auto parts and they had never even heard of mopar! WTH? (must of never heard of a Dodge eather) So where can i get it? Or what is equivilent to Mopar ATF+3 thats not going to reduce the life of my transmission?
sssshhh its never been changed....
I thought it was my transfercase leaking so i changed that with Dextron III Automatic transmission fluid which is what the manual called for. It said I could also use the Mopar ATF+3 but obviously its very rare to come by.
Thanks
Mechaniczman
Old Aug 25, 2011 | 10:46 PM
98RangoSLT's Avatar
98RangoSLT
Dodge changed the spec to ATF+4 a while ago. Use Valvoline or Mopar ATF+4.
Old Aug 26, 2011 | 01:27 PM
adukart's Avatar
adukart
+1 98Rangoslt
Old Aug 26, 2011 | 02:17 PM
topdogcustoms's Avatar
topdogcustoms
+2 98rangoSLT
Old Aug 27, 2011 | 01:45 AM
IndyDurango's Avatar
IndyDurango
In your '99... no way would I use ATF+4, But then again, we have rehashed this to death in many other threads. Search away.
IndyDurango
Old Aug 27, 2011 | 03:05 PM
hydrashocker's Avatar
hydrashocker
Yes we have........LOL........And our opinions very on it.
However Dodge did issue the Technical Service Bulletin (TSB) calling for it's use in ATF+3 lubricated vehicals. TSB 21-010-06 http://dodgeram.info/tsb/2006/21-010-06.htm
Regardless, do not use Fully Synthetic ATF+4 in yours particular where it is leaking, it will leak more. The problem you have is that you have a leak at the marriage ring site as you have stated between the t-case and the trans. There is a weep hole between the two that lets it drip out to tell you if there is a bad gasket there.
It is either the transmission output seal or the transfer case input seal that is leaking. You have to pull the transfer case and you replace both seals to fix the problem. While you have it out I would make a gasket and fill the weep hole in so it won't weep out of the hole. There is a DIY write up in the 2nd generation Ram section. I did this very thing just a few months ago.
Dextron III Automatic transmission fluid is NOT to be used in the transmission in our trucks!!!! Now in the T-case is different, I know the manual does state you can.
Old Apr 22, 2014 | 01:14 PM
TMW's Avatar
TMW
ok what fluid should i use in my 99 4x4 5.2. all i can find is full syn
Old Apr 22, 2014 | 07:56 PM
hydrashocker
It's perfectly fine to use ATF+4 in your T-case, in fact it supersedes ATF+3. If yours is leaking you should fix the leak and you should be just fine. I don't believe you can buy ATF+3 anymore anyways. I recommend you use Valvoline ATF+4 Fully Synthetic.
Old Apr 23, 2014 | 10:48 AM
Old_School's Avatar
Old_School
I second that.... i also use Valvoline in mine and have noticed better smoother shift since i i went to it.
