Information
Old Sep 1, 2011 | 12:34 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default Information
Some members needed to know what tool to use on pulling off the harmonic damper pulley. The tool number I am posting will fit dodge durango, ram 1500,2500 and 3500, ram srt10, nitro, all jeeps, neon, intrepid, 300, charger, challenger, minivans, and stratus. the tool is sold by Matco MST9740C GM/Chrysler puller. By using this puller. And you don't need to remove the radiator to remove the damper.
Old Sep 1, 2011 | 11:33 PM
hydrashocker's Avatar
hydrashocker
Thanks for the Crankshaft Vibration Damper pulley part number.
Old Sep 2, 2011 | 10:30 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
added this to the FAQ thread so it should be easily searchable
Old Feb 16, 2018 | 04:46 PM
arkaneinc's Avatar
arkaneinc
You can also use a $20 Harmonic Balancer Puller from Oreilly / Auto Zone which is what I did. It works in a pinch or if you're cash strapped. There's a trick to holding it in.
