is it safe...
Old Sep 10, 2011 | 04:30 AM
OffTheTimeline's Avatar
OffTheTimeline
Default is it safe...
...to slip into neutral if I'm going downhill or fast enough to coast for a mile or two? How bad or is it for the gears and transmission?
Old Sep 10, 2011 | 05:10 AM
MoparMan1991's Avatar
MoparMan1991
Shouldn't be bad for anything. It'll help drop the RPMs down and increase your mileage.
Old Sep 10, 2011 | 02:35 PM
Moparkyle's Avatar
Moparkyle
Nothing will happen at all.
Old Sep 10, 2011 | 03:34 PM
adukart's Avatar
adukart
I wouldn't do it, when the you are coasting over a distance like that the pcm will turn off the injectors, but if it is in neutral the injectors are firing to keep the engine running. Food for thought.
Old Sep 10, 2011 | 03:38 PM
hydrashocker's Avatar
hydrashocker
It's not bad disengaging it, however engaging it can be hard on it. In reality, the trans comes out of lockup when you take your foot off the throttle anyway and also your throttle body is closed and injection is minimal during this time as well. I guess it would save you a little but I don't like doing it.
Now in a standard transmission, hell yea I will do that all the time, but not in a automatic.
Old Sep 10, 2011 | 06:26 PM
turbo2point4's Avatar
turbo2point4
if its auto just pray you dont shift to R then itll be bad for everything lol
Old Sep 10, 2011 | 11:12 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
as adukart said, shifting into nuetral while coasting downhill will gain you nothing, it wont damage the transmission, but will not gain you any fuel economy (will actually make it worse) for the reason mentioned, the PCM knows that the momentum of the truck is pushing the engine along so the fuel supply to the cylinders is REDUCED not completely shut off, but it is reduced in order to help with fuel economy.
Old Sep 11, 2011 | 01:33 AM
adukart's Avatar
adukart
Mine shut off, at least that's what I thought. I was pulling a buddy's ford f-150 on a car trailer down the interstate. We started descending on this hill that was a 5% grade nothing huge but my live readout shot all the way to 99 and stayed there. Until we reached the bottom then it when back to 8.
Old Sep 11, 2011 | 02:53 AM
MoparMan1991
The only way you will go into reverse is if you pull the lever toward you. You can freely push the lever into Neutral and it will stop itself, it's a safety design to help cover dodges ***. It is also something that manufacturers have been doing for many years.
Old Sep 11, 2011 | 02:57 AM
turbo2point4
Yeah but the possibility is there
