Locker or LSD?
Old Sep 12, 2011 | 02:35 AM
MoparMan1991's Avatar
MoparMan1991
Default Locker or LSD?
I have 3.55s and I don't need anything more, but I would like to be able to get more traction at all times. As far as sharp turning goes I rarely make U turns. I would just like to know whether I should get a LSD installed or just lock my axles together. Give me some opinions. I have already priced a LSD parts plus install for about $800. I would just rather not have to deal with all those fancy clutch packs and what nots.
Thanks in advance!
Joe
Old Sep 12, 2011 | 04:21 AM
srch4me's Avatar
srch4me
if it was me i would go with a selectable locker or a detroit locker. i like the arb air locker... i wouldn't go with a solid locked rear.
Old Sep 12, 2011 | 01:11 PM
adukart's Avatar
adukart
I prefer lsd's, just for towing purposes which you don't do by the sounds of it. I don't think you can get an ARB for the D's rear end, but detroit locker are available. Go with the locker, you will be happier with it.
Old Sep 12, 2011 | 02:07 PM
srch4me's Avatar
srch4me
adukart yes you can... look it up. i wouldn't post it if you couldn't... at least i can for my d.
Old Sep 12, 2011 | 04:15 PM
adukart's Avatar
adukart
Ok so I looked it up, I now stand corrected. I had read the ARB application guide wrong, I looked at the diff cover N/A. Wow, feel kinda stupid, thanks for correcting me search.
Old Sep 12, 2011 | 05:15 PM
srch4me's Avatar
srch4me
no worries bro... arb is expensive though... a detroit locker will provide quite enough traction for a more affordable option...
Old Sep 12, 2011 | 10:18 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if your D is your daily driver do NOT lock it up full time, you will not be able to drive it constantly.
a lunchbox style locker is what alot of people like (it locks when you are on the gas, unlocks when you are not on the gas so you can go around corners without the rear skipping and bouncing all over the place)
Old Sep 12, 2011 | 11:04 PM
adukart's Avatar
adukart
+1 sharps, or you can put your foot in it and smoke em' although be prepared if you do this the price of tires lmao
Old Sep 13, 2011 | 12:32 AM
srch4me's Avatar
srch4me
the nice thing about the arb is it gives you an on rig air source and you can lock it when you need the locking ability
Old Sep 13, 2011 | 04:58 PM
hydrashocker's Avatar
hydrashocker
Well if he is not using it for hard core wheeling then LSD will work the best hands down. The only reason for a locker or posi is to give you more traction and lock each wheel together so they turn simultaneously. The only reason for that would be off road......IMHO
