Few problems
Hi again
Have a 1999 durango 5.2l 4X4
been trying to find out why my cruise control wont work and where the fuses and such are.
Also my fogs won't turn on there is no problem with the wiring but like the cruise problem can't locate the correct fuses and such.
any help would be much appreciated.
Thanks
Thanks
Have you looked in the PDC or in other terms the fuse box under the hood. When you say the cruise won't work you mean what, like the light on the dash will come on but it won't engage or the light won't even come on. More info please
And the Fog light problem is fixed bad connections on both lights.
The light comes on when you push the cruise on/off button and goes off well when you hit the button again. You will know when it engages because it will pull the peddle away from your foot momentarily. It sounds like the light is out or bad steering wheel controls.
