My first Durango
Old Sep 30, 2011 | 03:02 PM
  #41
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
afaik there were two systems available, ca emissions and NON CA emissiong (48 state is the term iirc)
CA emissions has 4 o2 sensors, 48 state systems had 2, in 2000 there was an extra setup with 3 i have heard, but never seen in person.
Old Sep 30, 2011 | 03:07 PM
  #42
adukart's Avatar
adukart
I've got one of those 3 systems, it has two for each bank like normal and one right after the cat just before the muffler. I would imagine 2000 wasn't much different from 1998.
Old Sep 30, 2011 | 04:16 PM
  #43
Old_School's Avatar
Old_School
Nope, most '98s have 2 sensors systems (non-CA)....
Per '98 FSM:
Old Sep 30, 2011 | 04:27 PM
  #44
Irondime's Avatar
Irondime
Ok I text him last night, and he stopped by in the morning and checked the codes. Before any work done it was throwing 2 codes, o2 sensor bank 1 sensor 1 and o2 sensor bank 1 sensor 2. Had the previously stated work done, brought it home then started doing it again. The code it had this morning was p0172 I think, system running rich. Went to his shop later today and we changed the pre cat sensor to a brand new one, seems to have done the trick runs good.
I had a little hesitation at a stop sign but it seemed to correct itself nicely, not like before were it would want to stall and lose power sputter and pop. I am going to go ahead and change the post cat sensor also, it looks just as old as the other one.
I gonna do a upper ball joint tonight.
Old Sep 30, 2011 | 04:36 PM
  #45
adukart's Avatar
adukart
You should reset the pcm so it will learn with the new O2 sensors.
Old_School I'll crawl under it this weekend and check, but I'm fairly certain I've got 3. Did it show how many pipes flow into the cat? I've got a dual inlet cat with a single out.
Old Sep 30, 2011 | 04:44 PM
  #46
Old_School's Avatar
Old_School
I posted a copy of whats in the manual.... if indeed you do have a 3 o2 system then its rare... as stated above.. i also never seen one before but, know there are a few out there.
Irondime: in regards to the issues.... check to make sure your park/neutrel switch is good and connected. I presonally had an issue where the truck was bucking/lack of throttle response... turns out that the wire for the switch had came in contact with the tranny and melted. once i replaced the wire all was golden.
Old Sep 30, 2011 | 05:43 PM
  #47
shrpshtr325
THE ULTI-MOD
i was going to offer the idea that maybe 3 sensors was CA emissions for pre 2000 and 4 was 2000+, i know the 4.7 CA emissions is 4,
Old Oct 1, 2011 | 11:36 AM
  #48
Old_School's Avatar
Old_School
That could be a possiblity too.... now im curious...
