Quick Help with Head Lamps on Durango (Electrical Question)
Old Sep 25, 2011 | 05:04 PM
Evil Juggalo's Avatar
Evil Juggalo
Default Quick Help with Head Lamps on Durango (Electrical Question)
A while back I installed some new headlights in my 02 Durango, and it was mostly a stock conversion and everything worked, however the lights were total crap..
So for my Bday my brother got me a new set, however the new ones only have a 1 running/blinker/hazer lamps as opposed to the old ones which had a spot for two.
With the wiring setup I have ive got the blinker/hazard/running lamp setup to blink correctly, however it still blinks really fast since 1 bulb from the line is missing and there is not place for a second..
My question is, is it possible to put a resistor in the socket in place of the missing bulb? if so, what Ohm res should I use?
Open to other suggestions.
Ive tried my google Fu at this but havent had much time to really check.. would appreciate quick responses.
Old Sep 25, 2011 | 08:30 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
just put a bulb into the socket and leave it tucked in there, it will provide the resistance you need and not make and visual difference
Old Sep 25, 2011 | 09:34 PM
hydrashocker's Avatar
hydrashocker
I've seen this before and I think the member soldered the leads together on the same bulb. Don't remember for sure tho.
Old Sep 25, 2011 | 10:29 PM
Evil Juggalo
well, I took one of the unused bulbs out and hooked it up to my volt meter and found that its ~2 Ohms, yes 2... So I dug around in my box-o-component but couldnt find one, so im gonna have the wife pick up a pack from Radioshack tomorrow on her way home from work.
Alternately, my dad told me about replacing the flasher with a heavy-Duty flashed which may also solve it.. But chances are Im gonna have to put the repair on hold till next weekend..
Thnx for the replies
Old Sep 26, 2011 | 03:17 AM
srch4me's Avatar
srch4me
lol... or just tell everyone your blinkers on speed :P
Old Sep 26, 2011 | 08:57 AM
laz45's Avatar
laz45
HA HA@ search...
