2000 4.7 conversion
Old Sep 27, 2011 | 04:13 PM
speedbt89's Avatar
speedbt89
Default 2000 4.7 conversion
Has anyone attempted to swap out this motor for the 5.2 or the 5.9. i figured the computer would be diffrent but how about wiring harness and exhaust. my motor just snapped a rod or something and the junk yards want 2000 for the 4.7..... Thanks
Old Sep 27, 2011 | 05:53 PM
Duranged408's Avatar
Duranged408
I can be done but in the end you will pay more than 2000. You pretty much have to remove everything from the donor and install.
Old Sep 27, 2011 | 06:55 PM
adukart's Avatar
adukart
+1 Duranged, everything is different including the transmission. You use a 4.7l out of a dakota or grand cherokee I do believe.
Old Sep 27, 2011 | 09:51 PM
Kensai's Avatar
Kensai
May just as well swap your 4.7 with the new modern 4.7 that makes over 300hp.
Old Sep 29, 2011 | 09:17 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 kensai, the new 4.7 is the way to go 310 hp out of it.
as stated above to put a 5.2 or 5.9 into a truck that came with the 4.7 you will need:
new engine
new transmission
new wiring harness for the engine bay
new pcm
new mounts
and i believe some of the radiator hoses are different
Old Sep 29, 2011 | 05:42 PM
hydrashocker's Avatar
hydrashocker
Yep, in other words buy a different one........
